Well im tryna remove the ignition cylinder from my 86 Fc and transfer it over to my 88 Fc since someone stole my ignition Cylinder for it. I cant find any bolts or screws or anything that will let me loosen it from the steering rack. Please help and thanks in advance.
Nobody Knows how to remove This? its urgent i need to get it out before i can start my project.
hammer.
There are two bolt on it, but those two bolt where broken from the factory. As the technician installs them they are over torqued and the top of the bolt sheers off, this is to prevent you from removing it. so you will need a drill and a set of extractors to remove the bolts to remove the key-cyl. then you need to find two similar style bolts to put it back on the other column. Good luck.
Swap out the whole colomn?
lol too late i just ripped out the ignition wire by an accident so ill have to order a another tumler im preety sure the dealership wont carry them any more but ill have to see ebay only has one listed also. Thanks for the help everyone
