ignition problem
ok replaced alternator fuel sending unit, fuel pump, coil, and gonna replace the distributor cap and rotor, engine cranks but wont start and doesn’t seem to be getting spark from any of the areas i’ve tested hence the reason i’ve replaced em, i just want to know is there a relay that would cause that or a fuse or some sort of thing that would cause the ignition system to just stop working?
91 240 KA
check your flow, remove the fuel rail and make sure fuel is coming out. if its not that make sure your getting spark… it could just be a clogged fuel filter and bad lines.
have fuel no spark checked all the fuses (that i know about) under dash and under hood all seem to be working no spark at coil wtf??? why?
