My friend just bought a 240/not running. I check the fuses in the engine compartment and I found out that their no ignition coil no relay nothing there, so I took a closer look to see if the wires were burried under the fuse box, and what I found was, that I do not see any wires that lead to the ignition coil/alternator relay, no cut up wires nothing.
so I’m just curious, of how am I going to fix this problem
this is probaly the reason why my friends car won’t light a spark when he cranks the car, other than that the car, great.
