I dunno id thought id spread the word that im putting a stock dsm turbo on a gsxr750, the manifold is already made and most of the lines are plumbed,
i plan on tuning with a AFC,FPR, and some stock LS injectors anyone have any input on the project?
ill grab some pics soon
smokeyburnouts:
sounds crazy
can’t wait to see that :eek:
sounds interesting. Post pics.
ill grab some pics tonight
the only real issue i am having so far is a stock dsm turbo is set @ 9 pounds of boost, that is prob to high for this application
so therefore i guess i have to cut open the wastegate trigger and cut a few rings off the spring,
hopefully it will be running by the weekend if all goes well
Quik
March 21, 2005, 4:03pm
6
what year gixxer? i may be interested in testing out that bike and how fast it is
sbr already made the kit…or is this their kit
on a side note we’re tryin to set something up for carbed bikes
its a 99 750 and its fuel injected
no one of my friends made the manifold
this is a low budget build
all i think i need is a pyrometer i have everything else to finish it
do dsm turbos “need” to be water cooled
there is a way to run boost through carbs
it’s a wet bearing so yeah i woudlnt change that setup or you might end up with metal in your engine prematurely
fmfkid250:
You can run it without a water cooled housing, but it won’t last nearly as long as if it was wet. How long for sure, I couldn’t tell you.
sounds sick Run it at 9lbs dont be scurred!
sounds like a neat project. hope it turns out well. so many of them dont…
do u think it would handle 9lbs???
that thing would make some power @ 9
im just waitn on a couple oil fittings
