I'm Doing It WRONG v computer help
trying to install new printer and i get this shit
dont know if this could be associated with the fact my itunes does not open
SOMEONE please help… if there is anything that can be done?
Check task manager to ensure our iTunes isn’t open.
Go into regedit and add the key manually.
the itunes is open in process but not apps?? im going to end all process
how would one add the “key” manually?
closed anything with apple or itunes and hit retry and still same?
uninstall iTunes, then reinstall it. Could just be a missing file or something. If that still fails download winamp and I’ll give you the code for winamp pro.
so the dll files are from that??
and send me the code im dl as we speek
Go to Run >> type regedit
Save your current registry just in case (File > Export > for the Range select all and name it whatever you want)
Then Follow the path in your screen shots until you find the key you are missing.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Cryptography\Defaults\Provider
If you are missing something after that right click on the last folder/key and click new and then key.
ok so did i do it right?
now do i have to save???or what
Nope…I thought that might trick it into installing…
no it did work for one
im going to try it once more
nope i added it 3 times and nothing?? could the winamp pro work ??
and i dont see how to make it pro… i added the info you sent me it said it was good
ok nm it says pro enabled … what changed ?
still need help with the printer!!!1!!11!
fucking FIXED… i put a " l " not a " I "… fuck
thanks for the help dude :tup:
in the registry key you messed up the letter?
Winamp Pro isn’t much more than basic. But if you use it to burn cds it allows faster burning and a few other features. Glad it worked!
