My buddy’s brother has a 97 Integra B18b (non vtec dohc).
They replaced the head this week due to 3 burnt exhaust valves. He’s got the car all back together, verified timing, installed new plugs/wires/cap/rotor. Car cranks, will not fire. Checked the plug wires against ground, they have a yellow spark (not blue).
He didn’t have his DVM with him, but his brother just called with the readings from the coil. Primary is 1.4ohms, spec is .6-.8. Secondary is 15.2k, spec is 12.6-19.2k. ICM is getting voltage. Checked all the fuses, fusible links and relays in the system, all are fine. Fuel pressure is good, recently replaced fuel filter, no blockage on the air intake either. Pretty confident it’s a spark issue, but can’t seem to track it down. Other than the primary circuit having slightly higher resistance, does anyone have any suggestions?
I would probably try some start-spray just for the hell of it to see where it sparks, then you would at least have a better idea where the problem lies.
I never understood acura, but their firing orders are all messed up, as a ford would be 1-2-3-4, but the wrong firing order could definitly cause the problem described…
check the firing order, and make sure the grounds are all hooked up properly, especially the one on the thermostat housing, ground problems are known to cause more problems than any
also make sure the plugs are all in proper locations (easy to switch the map and tps as they are the same style plug)
Definately check for good grounds. After installing the B18B in my crx I missed the ground behind the head. That was that ground for the ECU. Check if the CEL light comes on when the key is first inserted and turned to run. If not, it is an ECU problem.
