is it possible to heli coli aluminum head and how od you go about doing it
yes,drill, tap,insirt,& tighten:)
Sounds like the directions that Pewter’s wife gives him
:offtopic:
is there any way of drilling it out while it is still on the motor? i would rather not take the motor apart.
what is it!???
what is it!???
my bike, im concerned about if i drill and tap it shit will go down into the motor
what bolt??:rolleyes:
his spark plug
its my spark plug some how it blew out. put it back in blew out and stripped this time.
did u run a thraed cleaner throw it!!!put grease on it to keep the shaving from falling the the motor!
should i tilt the motor at all i havent done anything yet. i first have to drop the motor
now im pissed it installed a heli coil and now im fucked. put it all together and now the damm plug isnt far enough down in the chamber. how the hell do i go about taking it down alittle further or can i take it out and install a new one. i need about a 1/2 inch.
buy a plug with a longer sank!
i just spent 750 for one. can i remove the helicoil
:dunno:
can i run it in deeper
