Hey guys, I need a wee bit of help.
Ever since I bought a car it’s been having this issue. I posted a couple times about it here but couldnt find a solution, now I have an idea, please read
I’ve had the car since December, and the first time it happened was maybe in january. Basically I tried to start it, and revs would bounce around 100-1000 RPM and then it would just die. While revs were bouncing the whole car was shaking A LOT. If I gave gas it revs up a little, but not properly… it makes a fucked up noise while revving and even if i keep the pedal floored it won’t go over 2000 and still bounce around. It would bouce around for like 30 seconds and die sometimes.
Anyways that happend pretty rarely… like maybe once every 2 weeks and usually when i started it up again it would keep dying for 2 or 3 times but then eventually stabalize and be ok. Sometiems it would be fine for liek a full month.
Then it happened once where i must have started it like 15 times and it just kept dying. Sometimes it wouldn’t even start really, like it turns over and then “starts” and by “starts” i mean it goes to 100 rpm for a split second then back to 0. I Left it for a while then it started fine. This scenario was very rare.
I really had no idea what it was bit I knew 2 thigns: 1 is that it NEVARR happened on a cold start. Cold starts were 100% fine. It also didnt happen when u kill it and turn it on RIGHT away. SO basically if you left it for a while, not too short and not long enough for it to cool off there was a chance this would happen :(.
Today it happened again, and I popped the hood trying to look for something that would fix it (me being the dumbass when it comes to cars it was probalby not useful). Note that I tried starting it like 10 times and it was at the point of dying half of second after it came “on” to 100 rpm. Sod I put my hand ont eh rad hose, and it was fucking hot! I touched my vavle cover and it was hot as fuck too! I Couldn’t keep my hand on it for 1 second. This sounds stupid but as this is my first 240 I dont’ know how hot its supposed to be… does what I described seem like its too hot ?
So I got an idea…I blasted my heat for like a minute and started it, and guess what, after shaking around and being annoying for a few seconds the idle actually stabalized and it was fine.
So could my car be overheating? I look at my temp guage 24/7 but I think it sucks as devin on here said his coolant was boiling and it still showed normal temp…
My coolant is kinda dirty, I need to flush it soon, will this fix the problem? I also don’t have a clutch fan, and according to Marc it’s been like this fore ver and it never overheated and it’s fine. He also never had the dying issue that I had…
Any ideas how to fix it? Does it sound liek its overheating ? I’m thinking of getting an aftermarket temp guage to monitor it more properly since the stock one sucks, is this a good idea ?
