I am having some major problems with my KA driveshaft fitting into my SR tranny. I have tried everything, jacking it up, kicking it, moving it, bending(slightly), putting it on without the tranny crossmember bolted, putting it on With the tranny crossmember bolted, etc etc.
The tranny and the driveshaft both line up but the driveshaft is about 1 inch from the output shaft(? i think that is what it is called) on the SR tranny.
I am kinda pissed and cannot figure out what to do with this…
Yes I removed the dust cover from the SR. I am using the output shaft from the ka. Like I said, it lines up…the bolts line up, the shaft lines up, it is just 1 inch to far to actually bolt in.
