Hi everyone, some of you may have read my previous posts, but I am fairly new to the world of Nissan and need some help on the ka motor.
I just recently purchased my 240, and have finished all the work that  it needed…
- new rad support (welded one in)
- gas tank
- front stabilizer bar and brackets
- front struts
- injectors
- a damn good coat of underbody protection
- new radiator
Before I started my work, the car ran fine, no problems
I just finished doing all the work it needed done this weekend and left it run (but stupid me) let it run out of gas.
I filled the tank again (from gas cans), and cant get the damn thing to start.  I checked for fuel and spark and its actually getting both.
I dont know what the problem could be?..maybe a sensor?
I have no clue how these engines work or what goes wrong with them as I have always worked on Honda’s.  What do you guys suggest?  I did run the ecu in diagnostic mode and got the following:
2 long blinks
3 short blinks
4 short blinks
4 short blinks
then one long blink (i’m guessing this is to tell you its gonna restart the code)
then it ran the above again…
Anyone knows what it means?  I have no repair manual and could use the help
Thanks!!
              23 - Idle switch (throttle valve switch) signal circuit open
44 - No trouble codes stored in ECU
These are the codes you describe.  I would double-check.  Here are the rest:
11 - Camshaft position sensor
12 - Mass Air Flow Meter Sensor
13 - Coolant Temperature sensor circuit
14 - Vehicle Speed Sensor signal circuit is open
15 - Mixture ratio is too lean despite feedback control; fuel injector clogged
21 - Ignition signal in the primary circuit is not being entered to the ECU during cranking or tuning
22 - Idle speed control valve or circuit
24 - Park/Neutral switch malfunctioning
25 - Idle Air Control Valve
28 - Cooling fan
29 - Fuel system rich
31 - ECU internal problem
32 - EGR malfunction (California models)
33 - Front O2 sensor
34 - Detonation (Knock) Sensor
35 - Exhaust Gas Temperature sensor (California models)
36 - EGRC-BPT valve
37 - Closed Loop
41 - Intake Air temperature sensor
43 - Throttle Position Sensor
45 - Injector fuel leak (California models only)
51 - Fuel injector circuit open (California models only)
53 - Oxygen sensor (300ZX right side)
54 - Short between automatic transmission control unit (TCU) and ECU
55 - Normal engne management system operation is indicated – this means all is OK.
65 - Misfire detected - cylinder no. 4
66 - Misfire detected - cylinder no. 3
67 - Misfire detected - cylinder no. 2
68 - Misfire detected - cylinder no. 1
71 - Misfire Detected - Random
72 - Catalytic Converter Malfunction
74 - EVAP pressure sensor
75 - EVAP leak
76 - Fuel injection system
77 - Rear O2 sensor
81 - Vacuum cut bypass valve
82 - Crankshaft Position Sensor
84 - Automatic Tranny-to-Fuel Injection Communication Line
85 - VTC solenoid
87 - EVAP canister purge control
91 - Front oxygen sensor
95 - Crank Cog
98 - Coolant temperature sensor
103 - Park/neutral switch
105 - EGR and canister control valve (Solenoid)
108 - EVAP volume control
111 - Inhibitor Switch
112 - Vehicle Speed Sensor A/T
113 - A/T 1st Signal
114 - A/T 2nd Signal
115 - A/T 3rd Signal
116 - A/T 4th Signal or TCC
118 - Shift Solenoid/V A
121 - Shift Solenoid/V B
123 - Overrun Clutch S/V
124 - TOR Converter Clutch SV
125 - Line Pressure S/V
126 - Throttle Position Sensor A/T
127 - Engine Speed Signal
128 - Fluid Temp Sensor
(From a GUIDE I found)
Good luck.
              thanks for the reply, i’m sure this will help, thanks!
