here’s a trouvleshooting question for everbody with a brain, if you dont have one, please dont bother trying…
having a real problem getting a friends ca18det to run properly
symptoms
at about 4k, right when the motor is just getting under load (it revs freely, as long as there is no load) it has a sputter, and backfire, like a cylinder or numerous are not getting air fuel or spark, basically at 4k, a dead cylinder comes up
Ecu is throwing code 13, but that is not enough to do this. (eng temp code)
No boost leaks (unless the IC core is fucked)
Injectors. cas, coil packs, ignitor, and a few other parts have been changed out to nulify possible causes.
here’s my thinking…
I am beginning to think maybe the fuel filter is clogged??? cause every time the fuel system had the pressure releived, the car ran good after for a couple minutes.
and more to point at the fuel filter, it does not rev fast like other ca’s I have driven and worked on. It just has slow and gradual acceleration.
I have my doubt’s about it being the maf, I know it’s not a mechanical issure either.
ANy body ever had the same issue?? And anyone ever had a clogged fuel filter?? symptoms???
this is the mods to the engine
mines ecu, fmic, 440cc and 370cc injectors (we have tried both), 300zx tt fuel pump, ka24de fpr (I know it has like 3psi differece between stock ca one) hks exhasut, t28 (newer garrett unit, directly from garrett) seconday buterflies have been eliminated and removed, intake mani, and sec. mani have been ported, and I think thats aboiut it’
here’s the weird thing
when this problem first occurde, I changed the injectors out, and it ran perfect for about ten minutes.
I recently did the head gasket and a full gasket kit/timming belt for him, and when it was in the car it had about 1/2 hour idle time, and ten minutes of bagging (hard), then they were doing a brake stand, the car has a very minor stumble and they came back to the shop, and we found and Ic pipe had cameloose, fixed the ic pipe, and guess what the same stumble issue is now back.
so the only thing consistent to me is that both times it ran good was after the fule system had all pressure releived. maybe the filter has some matter in it???
give me some help guys.
peace
jason
I’m tired, hopefully this makes sense
and another one, found 2 sources listing different head stud torque specs for the ca18det, does anyone have an FSM?? I need to prove somebody wrong… he says 80 pounds… I dont think sooo… bu need a outside thrid party for him to beleive me anyway./
