hello, I am of Mexico and have a doubt I hope help me, have lt1 in project all the parts almost ready and want to know that they advise to me, I have doubt in injectors? computer programming? thanks for its aid and I put the parts here to them that use.
factory block injectors and computer
trick flow ported 195,s heads 2.02 and 1.6 valves
383 balanced stroker kit keith black pistons in 40 bore
hypertech III programer
ported 54 mm throtol body and maf
3000 torque converter
transmission shift kit
large headers 1.3/4 primary tubes
CCA-07-306-8 competition cam 510 and 540 intake and exaust
factory flexplate and damper
race fuel pump
4.11 diferential gear and posi loc
race tires 28x10.5x16
thanks for yours comentaries !!! sorry for post in this area please mods move this post
If the engine is internally balanced you’ll need to have the balance weight removed from the flexplate. Might also want to have a machine shop check that the flexplate is neutral balanced after the weight is removed. I assume the heads came with upgraded springs? Using 1.6 ratio roller rockers. Make sure to check your pushrod length too. Stock length might not be right anymore.
thanks friends, I am in monterrey Mexico and we are preparing that car I hope work very well, will try to obtain the injectors that they recommend to me, and I am going to test hypertech programer and later she will program the computer where you they recommend ,the 383 kit not it and even balanced, crankshaft it is external balance not that they recommend to me the crankshaft number in summit is ESP-103523750 my rods is 5.7 scat i beam keith black pistons and factory damper and flexplate? and my rocker,s if they are of 1,6… thanks!
