Megasquirt Help Please
Ok to start off I have a 1993 nissan 240sx with ka24de now has a turbo with a front mount intercooler installed.
I am picking up a set of 550cc injectors for the build.
Right now I have the car set at 3-4 psi of boost on stock ecu and setup.
I have sitting on the table a Megasquirt 1 version 3.
I am looking for the best way to get a base tune or if someone has a tune for the car that I could get off of them.
The plan is to run about 9 psi and have it running good and reliable. I am new to the whole import tuning seen and these megasquirts. I have friends that have wired in a few of them before and have tuned them but I need to get my hands on a stock tune or even a good tune that will let me run the 9psi without much tinkering.
Thank you in advance for any info or help givin,
Brad
the best feature of megasquirt is its autotune capability. Set it at a desired AFR and let it works its magic.
Ok but how would I get a base tune so it will start and run half decent at first?
Check Kat-t.org
Hey
Send me a PM with your phone number. I’ve built 2 240z turbos using Megasquirt Ver 2 (Fuel only)
I’m sure I can help you get it going. I’m just over in Brantford
Jeff
