actually not sure exactly how im gonna break the engine in yet. Considering I might run the car on the dyno or do a bunch of really slow laps at the track before doing an oil change or something i dunno.
other than the pistons only other things are new bearings valve seals rocker arm stoppers and a metal head gasket, just a basic rebuild + repair really. I want to get her back on the road (err track) asap.
other than the pistons only other things are new bearings valve seals rocker arm stoppers and a metal head gasket, just a basic rebuild + repair really. I want to get her back on the road (err track) asap.[/quote]
For people who don’t understand valve float and why it is death to a engine here is a summary.
A high-rpm engine condition in which the valve lifters lose contact with the cam lobes because the valve springs are not strong enough to overcome the momentum of the various valve train components. The onset of valve float prevents higher-rpm operation. Extended periods of valve float will damage the valve train.
When the valves fail to completely close during the compression stroke, and/or can sometimes bounce off of the valve seat as it tries to follow the profile of the cam. An engine suffering from valve float has a characteristic sound; the engine will begin to cut out, making a rumbling noise. Valve float causes loss of power and usually leads to engine damage.
I personaly would not use just stoppers since its not really a great way to solve the problem a better way would be to upgrade your valve springs to a stronger rate, this will overcome the problem and allow you to rev the engine harder without worry of the valves loosing contact with the cam.
P.S. Valve float was a very common thing on pushrod engines
what they physically do is they sit very close to the lifter side of the rocker so that during valve float if the rocker bounces up to try and shift it wont be able to come off the lifter, and if it cant come off the lifter then it cant fall off and cause rocker arm damage due to the geometry of the system, it wont allow it. Well… it would allow it when the engine is off but when running it would be really hard, the springs would have to be almost all the way down while the cam was off lobe and then there would have to be a turning force to turn the rocker away from the springs, probobly from vibration.
Without rocker arm stoppers at high engine speed the rocker is floating and if the springs are low the rocker can lift up on the lifter side and not land flat back on it, causing it to slide off and then you have rocker failure because the cam slams the rocker that is half sitting on the grond, the easiet thing to happen is for the rocker to break.
Sasha if you are getting the pistons droped in by professionals, get them to make the tolerances on the ring gap such that you only have to run the engine at such and such rpm to seat the rings only. The sides of the pistons (the name escapes me) should scuff up nice after this as well.
Then take her for a few light laps around the track with varying rpms and loads. Your bottom end bearings can be done in this way as well, however as long as they are in tolerance bearings these days are quite robust. The most important part is the seating of the rings.
I’ve seen this done on race motors, I never quite understood how they knew. But the have some special break in oil and hold the engine at around 3000 rpm for about 20 minutes.
respectively, you should really use the qutoe feature to indicate that you really didn’t know the answer so you had to search for it on google. It will also keep you out of trouble with the plaigerism nazis.
yea i takled to ceaser from missisauga engines regarding break in procedures and i’ll be installing the pistons and trimming the rings myself, from what i understand you set the ring gap to the boost pressure and rpm you will run not the break in procedure?
I’m going to try to get my car ona dyno for a couple hours for a quick break in, from what i’ve been told that and an oil change will be good enough.
Now i just need to find out what oil to use for break in. I’ve heard some saying not to use synthetics, others say use, then there is the money issue.
ive always been told to run the cheapest crappyest oil you can find for break in and then switch to synthetics,aparrently synthetics provide such great lubrication there is very little friction on the surfaces that need to be broken in
but on the other hand the tolerances are so tight on our jap scrap motors that we really dont have much of a break in time as opposed to the engines of yesteryear
