Okay so last Friday the 14th I received my sr20det from Dj-Infinit kindly enough he even delivered it. I am a gr12 high school student, I am rebuilding this engine at school because of resource to tools. I am not new to 240’s I owned a s13 hatch with a ka sohc and swapped a RB20det into it. Sold it and now im 240less. So back to the build, on Friday when I received the engine, I got it out of his van, and put it on a tire for the weekend. Im taking my time on this build Im in no rush. So I left it for Monday on the tire. When Monday came around and no one could stay so I had to leave so no work done Monday [FONT=Wingdings]L[/FONT]. Tuesday comes, lunch I pull the clutch and pressure plate off, put it on a stand and call it a day.
Wednesday I had my exam all I did was pull the valve cover off and start stripping it down for paint.
Thursday finally some work gets done, I brought my girlfriend to help, she did basically all the work, she unbolted the front cover, the cams, took off the rockers, unbolted the oil pan, all I did was take off the head bolts, also to my excitement I found ARP head studs when I pulled off the valve cover.
When we pulled off the oil pan I was a little concerned, I found a piece of a rocker and a rocker guide. But all my rockers were in good shape and I wasn’t missing any guides, so what I suspect was someone threw a rock and replaced the head because the serial #’s don’t match up. Anyways that was about all we did on Thursday.
On Friday my girlfriend came and helped out again, we pulled the pistons, crank, and all the internals out. The cylinder walls looked to be in good shape, I might hone them and I will be installing new piston rings, when we pulled the main caps off to inspect the bearings they weren’t TOO bad for 20 yr old bearings but they looked like they were ready to let go. Also the pistons looked like they were burning oil or running very rick because they were coated in carbon deposits. Other than that the motor looked to be in good shape on Monday the 24th I will begin blueprinting the motor. Also getting the block boiled later.
---------- Post added at 02:55 PM ---------- Previous post was at 02:40 PM ----------
cylinder #1
cylinder #2
cylinder #3
cylinder #4
organization is key!
---------- Post added at 02:56 PM ---------- Previous post was at 02:55 PM ----------
thats all till monday!
but thanks
i also picked up some engine block de greaser, it didnt work to bad? i guess, but i ended up using brake cleaner and wire brushes for most of it. so i started off by getting all the old silicone out of the oil pan bolt holes, i used a small drill bit and compressed air witch worked great. then i used a scraper to clean the surface for the oil pan.
