Ok, so I had my tranny/clutch replaced and everything was all good for about 2 weeks.
I drive a '95 S14 SE and after about 2 weeks, I noticed 4th gear starting to jump. If I’m going about 60km/hr in 4th at 2000RPMS and floor it, it will quickly jump to 3000RPMS and drop back down…the car barely accelerates but the engine revs hard…then after 3000 RPMS its fine…only that range in 4th.
Just last night, the check engine light comes on so I pull the ecu, check the code… 103… parking/neutral switch. Do you guys have any thoughts what it could be? 1 of the sensors maybe? the neutral switch? or a bad tranny?
Ok well we changed all the sensors last night and still the same problem.
I get this in 4th and sometimes in 5th…its only in the 2000-3000 RPM range, where it feels the engine is just barely connected to the tranny…its barely pulling and then it grabs again when i let go of the gas.
