moving Power windows up, with NO battery?
I need to put the windows up its a '92 hatch. The car is just a rolling chassis so there is not much to work with. Is there a way i can take the door skin off and hook up some type of battery right to the motor it’s self??
yes
you can run 12v direct to the motor’s harness… you just gotta figure out which pins to connect
Alright thanks man, i guess ill just randomly try different pins, trial and error!
follow the leads from the window motor -there is a 2 connector plug-disconnect and apply 12V DC -to move window in opposite direction reverse the + and - wires from your 12V source - I use a spare connector wired to a small 12V battery to make it easy
alright that makes it alot clearer, thanks alot man.
yea if you have em on the wrong way then it will either roll the windows up or down,
if they roll down, switch sides then they should roll up
