My window all of a sudden stopped working, while it was down! I need to fix this ASAP . I allready have the cover off and have no clue how to get the motor out as there is voltage going to the motor so its not the switch. If you have a working motor I will buy it too! and PLEASE tell me how to get it out!?
Gonna hate hearing this but if the cover is off that is what you have to work with. I can’t remember if the motor sits in front of or behind the glass.
More then likely your going to have to pull the glass from the guides to get at the motor. It is very tight but it will come out.
removed blockers that stop window going up to far, on the inside of the door. dosent need to be loosened all the way it will slide out if you move it up.
glass unbolted(4) from track/motor then removed, moving the window up and down to get at the bolts helped(when reinstalling lol).
then the track came out with 4 more bolts, having the window holders down helped it come out smooth.
the motor is attached to the track and comes off with 3 screws.
