yeaaa so the silver miata started pissing coolant out of the head gasket on the drivers side this morning. Good thing I kept that other one. go go backup miata! haha
Look here for a fix:
http://www.monstermiata.com/
:+1
if you can get 6 more miatas, they can Voltron into a different mazda. miatas are magical. :lol man, it sucks though. do you have to change the headgasket now or what?
well I’ve got a second miata, so I’m driving that one for the winter (mine’s in better shape, don’t wanna put another winter on it) . I’m going to garage the one that is leaking for the winter and then do the headgasket on it later.
has it been leaking into the motor or just squirting it outside?
squirting it outside, it’s leakin out of the drivers side down the block
Should be a relatively easy job though, that’s good news.
Did it just piss coolant or now your oil has that milky color?
Edit: If it’s not mixed check all your hoses for cracks.
its not so bad if its all outside. hopefully theres none inside thats caked on something hot.
I haven’t checked the oil yet, just parked the car. I checked the hoses but I can actually see coolant leaking out the block where the head meets the block ![]()
at least u didnt get stranded 600 miles from home. uve got another car u can drive in the mean time, thats also a plus. coulda been worse, ya know?
