If u look in your car manual, theres a way to get the key out… first u have to get the plastic trim off the body of the steering column , that should reveal a small latch near the key hole. flick that and taaada. The manual illustrates that its only meant for emergencies only.
In that case, on 91+ models including all s14’s there is a cable which tightened when you put the car into any gear other than Park to make sure you dont flop out the key while driving.
In my Zenki s13 there seems to be an electronic control for this (wierd) and so all I do is basically press twice on the button and then it should come out fairly easy once you get the hang of it. You just have ti apply force as your pressing the release button. If it is a 91+ and you DO have the cable I suppose you can just snap it since its worthless…
You can find it if you take your shifter console out and right infront of the shifter there should be a cable there. NOOOOOOOOT the ebrake cable … you dont wanna snap that sucker.
