okay… so not having much money and another car you need to spend the money on as well, the progress on this car will be limited for awhile, but will hopefully move along. i will start another thread for my bmw, when i dig into basically completing the entire suspension setup, and other misc things.
i’ll start out with the mod/ current setup list:
-1991 jetta gli
-vr6 swap donor car 1995 passat glx
-100k miles on all swap parts from passat. new timing chains, head gasket, oil pan gasket, intake/ exhaust gaskets, rear main seal, axles, etc.
ENGINE/ EXHAUST:
-1995 obd1 passat glx 2.8l vr6
-k&n cone filter with custom made heatshield
-giac performance eprom
-magnaflow 6" round 2.5" muffler/ thrush 2.5" resonator
-cat delete/ complete custom 2.5" mandrel bent exhaust
-pcv valve bypass (air compressor separator as catch tank)
-throttle body coolant line bypass
-deleted carbon canister
-deleted air conditioning system
SUSPENSION/ STEERING:
-boge turbo gas shocks/ struts
-neuspeed sport springs
-5x100 5 lug conversion
-hubs machined to accept corrado front brakes
-deleted power steering system
BRAKES:
-corrado front brakes
-stainless steel brake lines
-22mm master cylinder
DRIVETRAIN:
-o2a passat transmission with tdi 5th gear
-hydraulic to cable clutch conversion
-mk4 jetta vr6 16" wheels (summer)
-falken ziex ze512 205/45/16
-b4 passat 15" bbs wheels (winter)
INTERIOR/ I.C.E.:
-jetta gli recaro seats/ door panels
-schroth rallye 3 bolt-in harness
-passat shift knob/ boot
-wink 5-panel mirror
-autometer sport-comp gauges: speedo/ tach/ fuel/ water temp.
-clarion dxz-435 head unit
-beltronics pro rx-65 radar detector
-performance technique 1000w 4 ohm dvc 12" sub
-q-logic enclosure
-kenwood coaxial speakers front/ rear
-ipod aux. hook up
-autotek 5 channel amplifier
EXTERIOR/ LIGHTING:
-single round badgeless grille
-kamei style eyebrow
-gli trunk spoiler
-quick release refreshed front “big bumper” cover w/ 16v lip
-color coded rear vw emblem
-shorty aluminum antenna
-european license plate tub w/ europlate
-dj auto smoked crystal single round glass headlights w/ city lights
-m3 style smoked tail lights
-smoked side markers (bananas)
-smoked front indicators
-mono-wiper conversion
COMING SOON:
-stainless steel headers
-“euro clone” 2.9l intake manifold: gutted/ polished
-ported throttle body
-autotech 262* camshafts
-lightweight lifters
-h.d. valve springs
-weitec 60/40 springs
-front/ rear strut tower braces
-custom molded fiberglass sub enclosure
-oil temp./ oil pressure/ volts/ air fuel gauges
probably more…
the headers and front end bits will probably be the next items i address. i have the bumper cover ready to install, and i’m using some black hood pins as my bumper quick release setup. i just finished roughly cleaning up the cover and will install it and shoot some new pics as soon as the pins arrive in the mail. there are a few more things not pictured like the water temp gauge and the sub & amp.
i also pretty much came to the conclusion it is a better idea to keep my daily n/a and just boost the m50. the bmw will only be run during spring through fall for obvious reasons, which i won’t even touch on now. here are a few pics of the gli as it stands. none of the euro plate, and euro plate tub yet though, will get them when i shoot the front bumper.
i will try and update the thread as often as possible. enjoy! ;D
:wtf
