drivig down the highway or racing as soon as i hit about 120 - 140km full throttle is cuts out as if topped out. can anyone tell me something?
Check fuses, same thing happened to a customer of mine.
Rear defroster stopped working, governed out early and had no temp guage or speedo.
If you dont have a blown fuse, unplug the battery for about 10 - 15 mins & let the ECU reset itself. If its still screwed, check your fuel pressure at higher rpms, if its cutting out due to excessive pressure drop, change the fuel filter.
If you need more help I have a shop in east GTA if you are anywhere near there.
and I just read you were located in Ottawa, so unless you like to travel, I can only hope you have a bad fuse.
It’s a fuel dilevery problem.
I had that issue with my winter beater.
Check Filter, Sock, Pump, Injectors etc.
does your speedometre work? cause if it doesnt you need a new speedo, that used to happen to me till i put a new speedo in and its all fixed
Where anywhere did he mention he had a speedo issue?
i was just asking if he did no need to be an ass
