I have a few pictures. I’ll post them all together in one update.
. Thanks dude. I’m pretty stocked with it. Just need to make a rear trans mount and then I can start welding. The Bridgeport is pretty tied up at the moment, so I am going to try to re-use the existing parts.
<= part co owner
Mark knows how to bend and weld very well. Even took some machining classes to build on his talent.
He has skills and could prolly whip up some nice handle bars for ya if u wanted?
Most of the stuff in the transmission was in pretty good shape. The main drive gear bearing, however, was totally whooped and it took out the mainshaft. The clutch rod throwout bearing was disintegrated, but none of the parts were in the gearbox… so they must have been blown apart for a long time.
I was given a brand new main drive gear that already had the bushing in it. I bought:
Baker N1 jockey top (shift pattern is N-1-2-3-4)
New mainshaft
Full rebuild kit (included countershaft and shift shaft)
Every bearing inside
Throw out bearing kit
Shifter alighnment tool
Adjustable hand reamer for kicker clutch gear bushing and kicker bushing
Had to make some more tools to R&R the bearings and seals. The tools I made are on the right. Just a few of the parts I replaced are on the left
Got the frame 90% welded and out of the jig. Thanks for the help with everything, jay. There are some welds we couldn’t hit while in the jig, so need to finish those up and cap the tubes at the dropout. Otherwise, it’s sweet as hell.
my hardtail rode better then my lowered swing arm bike. Solo seats have come a long way these days whether its mounted with a shock or springs. Im assuming the frame isnt done on the bottom where there is some pretty severe undercut? probably where it was jig’d. lookin good otherwise. any idea on the seat yet?
