This year was great Lana. I purchased the car in December 2009, built the car from the ground up with STM, and then had some excellent runs at the track. The car is put together very well, but I want to perfect a few little things I neglected over the year. This build thread will highlight those tasks. Things I have in mind are:
- Rewire the headlights to have complete, factory working high/low beams
- Wire my fans and electric water pump to key on, instead of a switch
- Wire my fuel pump to a toggle switch, for high and low settings
- Misc. cleanup around the car, inside and out
- If all goes to plan, extend wires and place the entire fuseblock behind the dash
I just started tearing down the front end tonight so that I could inspect the headlight wiring, and figure it all out, and I wanted to show how easy it is to work on this car!
I pulled the STM small battery and Buschur Racing battery tray out of the car with 3 bolts. I am such a fan of small batteries!
Next step to remove the front bumper is to remove (2) 10mm bolts, one in each wheel well:
After that, you simple pull the 2 pins on the fabricated radiator mount, and lift the entire bumper off. Yes that’s right, just 2 bolts, and 2 pins to remove the bumper:
Now with the bumper off, you can see how everything goes together on this car:
After that, it’s 2 bolts on each headlight, and they come right off.
And I know you all believe me, but yes, it is a stock IX turbo that we used to go 10.635 @ 128.70 on the first night running the car at the track :tup:
I am going to try to get my hands on a factory service manual to continue from here, but it looks like there isn’t too much wiring that goes forward from the fuse block. If you look here, you can see there is the headlights, the fan relay, and the electric water pump. I should be able to take the wires out of the loom, consolidate some grounds, and get this bundle under control!
I am debating on pulling the fenders off, so that I can get to the wiring better. I know the side markers have wiring under there, but I am not sure if there is also a loom that goes to the interior of the car, or if all of the wires go through the fire wall. It’s time to dig in. Wish me luck!
I will try to keep this thread as updated as possible, as I continue over the next few months.
–mark
