Mysterious ticking sound
So all the sudden I have a constant ticking sound, no matter what gear, what speed its always there and constant, even when rolling and I turn the car off, still there.
Except when I’m about to stop, rolling at about 3 KPH it turns into a whining noise, which tells me it’s a rotating part coming to a stop.
Now it sounds like its coming from the tranny area, I was hoping others had this symptom before and could tell what it is.
Thanks for the help.
It’s an S13 SR if that makes any difference, it shouldn’t.
relay…?
I have had similar symptoms from these…
it could be a u joint in the drive shaft starting to go. they make all sorts of weird noise when the get dry…im not sure if the ones in the 240 have a grease fitting or not.
