I’m buying a car this week and it needs a clutch. Anyone have a recommendation for a shop in the North Side/North Hills area to get it done?
As for what I’m buying? 1992 Suzuki Swift GTi. Think this car + color, but on stock 14" alloys.
nice rebadged geo metro
it’s a Metro with twice as much horsepower…
(i.e. a half-dozen hamsters under the hood
Originally posted by ShalerPunk
it’s a Metro with twice as much horsepower…(i.e. a half-dozen hamsters under the hood
so how more power can you actually get out of a 3 cyl.
I’m buying a car this week and it needs a clutch. Anyone have a recommendation for a shop in the North Side/North Hills area to get it done?As for what I’m buying? 1992 Suzuki Swift GTi. Think this car + color, but on stock 14" alloys.
my parents do alot of buisness with high tech automotive on 3 degree. are you buying the clutch and jest need it put in or what.
DONT TAKE IT TO COTTMAN
Originally posted by BlkP42E
my parents do alot of buisness with high tech automotive on 3 degree. are you buying the clutch and jest need it put in or what.DONT TAKE IT TO COTTMAN
yeah… i can get a centerforce clutch for $135, but i’ll need to have it put in… i’ve always wanted to learn how to do a clutch, but i’ll be too pressed for time to attempt it myself.
and everyone’s told me not to take it to cottman
its a 3cly,losen the motor up lift it up!!!u may need help lifting it!!!but pull the motor to do it!!!those motors are light!!!
u can do it in a day!!!
Originally posted by Pewterss
its a 3cly,losen the motor up lift it up!!!u may need help lifting it!!!but pull the motor to do it!!!those motors are light!!!u can do it in a day!!!
a metro is a 3-cyl…
the Swift GTi is a DOHC 4-cylinder in the same body as a Metro.
a metro is a 3-cyl…the Swift GTi is a DOHC 4-cylinder in the same body as a Metro.
then which motor is that
so its still light!!!if u cant pick it up,use a comalong & a tree branch!
G13B… DOHC 1300cc four cylinder
you need a life not a clutch
my buddies may be able to do it. up by NH highschool
the clutch and labor probably cost more then the car is worth
let me know. i can tow it there.
you have a pm, im on aim now
I’m really into Swift GTIs… back when I had a Metro I always wanted to do the swap… They’re pretty cool, for what they are. 100hp in a car that weighs under 1700lb, and there is a huge aftermarket… www.ssgti.net has a lot of shit for it.
man your weird. your interested in a car that makes less power then the last car you owned. also geo metros look like clown cars. youll be able ot notice if you ate to much in that little weak car. save up and buy something else
STFU to each there own!!!:rolleyes:
yes sir, all mighty one
