need computer/mp3 help...
i just bought the fuzik phone at sprint today, its basically an ipod and a cell phone together. well, i took the phone home, hooked up the memory card/usb line to my computer, and hit sync. well, it said the little memory card in the usb drive(it said drive f on the screen) was protected. wtf does that mean? i bought the extra memory card for $40, and it holds around 125+ songs. heres the other probem. i live with my brother until i move to philly in april, and his computer is the one i use for the internet. mine isn’t online, i only use it to burn cds, and music, games etc. so, how do i get my com;puter to download on the phones memory card.? the salesman said it will work fine, and if not, return the card. but the whole reason i bought the phone was to have the ipod.
Usually there is a little tab on the card that will prevent the data from being over written, check for it on the card. After that you should be able to get stuff on there. On your computer you will probably just have to connect the phone to the computer and then run the software to get access to the phone with the card inside it and then download the music to it…
cool, where/what does the tab look like? i have the card, and it looks like a little disk.
It would be a little slider thing, the card should have come with a little manual and it would be in there somewhere… What kind of memory card is it? Probably MiniSD
im a complete computer retard man. it is a 512mb card, and it is used for holding songs. i finally got it to download, bit it won’t play when the phone is closed, only when open, it says no file. if there is no file, then how can it play when the phone is open?
i don’t know how the fusiq works but on my sprint razr(red) you have to make sure it goes into a folder called “MUSIC” and if i’m correct that phone is probably using music store to play the music right?? www.howardforums.com look under the lg forum and the sprint forum
