Step 1: Inserd SD card into card reader on laptop.
Step 2: Copy/paste MP3’s onto SD card.
Step 3: Remove SD card from laptop, insert into Samsung i730 Windows Mobile 5 smartphone.
Step 4: Observe that files don’t appear.
Step 6: Ask NYSpeed for help.
Step 7: ???
Step 8: Profit.
So what’s the deal? If I copy/paste to the card when it’s in the phone and the phone’s on the data cable and Microsoft Activesync is running, no problem. If I copy/paste to the card through a card reader the phone can’t recognize the files. Any workaround?
Is there a specific file structure to place the mp3’s in? I know on every phone I’ve had you can’t just drop the files onto the card, but a specific directory and then they show up.
When you copy and paste to to the card when its in the phone, don’t delete the files, plug the card directly to the PC, and then try to locate the files, add more files to the same file location and see if that works.
Crap, left the card in my laptop at work. I’ll double check. This is also the same card I had trouble formatting until I tried it with my cannon camera. I’ll check what format the card wound up in.
I can write to the card through the phone like Chino described just fine. I can read/write to the card with a card reader just fine. I can also read files with a card reader written to the card through the phone just fine. I just can’t read files with the phone that were written by the card reader. :gotme:
I’ll double check the file format of the card tomorrow.
Copy a MP3 (that is currently recognized) off the phone to the PC.
Drop it onto the SD card and see if it recognizes that file which you know is good… that will at least eliminate some possibilities.
It is possible that the phone writes to a “directory” file somewhere which tells it what files are present. Just a guess.
Weird. I shut the computer down last night with the card still in the slot on the computer. Started the computer back up this morning. Popped the card out and into the phone. Now the phone sees the files. :gotme:
So I started filling the card with MP3’s, but it gave me the “disk full or write protected” fuck you at 1.1 gigs, so I tried to format it. Still won’t format, so I’m going to grab a new one from Best Buy tonight. If that works I’ll just return the old one in the new one’s packaging. The thing’s only like a month old so either way I’d get a new one, but this just sounds like so much less paperwork. :tup:
The computer Gods were smiling on me though. 3 months ago this card was full of 2 gigs of irreplaceable wedding and honeymoon pictures. As soon as I emptied the card, it seems to have developed sort of a bad spot 1.1 gigs in. Thank God it didn’t shit the bed with all those pics on it.
