SD card issues
bought a 2gb sd card for my phone, was putting music on it and its maxing out at 500 megs, how can i correct this, i want the 2gigs i paid for.
How are you adding music?
Can your phone support a 2gb card?
Did you try to reformat the card? If so, what does it say for free space in Windows?
Windows says it has 2gb of space, I am dragging and dropping into the folder.
my phone supports up to 4gb.
im using a card reader not a data cable to my phone
reformat the card using the phone
ill see if i can do that.
I cannot reformat in the phone
any device that uses a memory card can reformat it.
what kind of phone is this? are you sure its the proper format for your phone? (ie. FAT32)
No idea but the phone reads the music files
it is a LG Shine, Micro Sd card.
I cant find it in the menus to do it on the phone
If its verizon it should be in a similar place of other phones.
Check Settings>Memory>Card Memory and then there might be an options tab at the bottom to format the card.
On my Samsung its Menu>Settings and Tools>Memory>Card Memory and in that menu I press the right top button and a submenu pops up with FORMAT CARD on it.
Its AT&T, I looked in that area and there is no option for Format card.
Maybe im just retarded, how do I reformat it at home on my computer when i get there. Im at work right now.
I want the 2gigs i paid for damn it.
check your manual or google for the pdf. any device that uses external memory has a way to format it so it can use it.
Ill check the manual when i get home.
If i format it will I lose all the data thats on it?
currently the phone is using the data thats on it without an issue
probably
I just want this to fucking work. I checked again in my phone
I go settings, memory
Memory card, it shows me how much space there is available and taken up and, I cant do anything else
Settings Reset Master Clear Memory Card
PW- 0000
went ahead and did that and deleted everything on the memory card, I will attempt to reload it tonight with all the 2gb of space.
Thank you very much Mr.Boxxa
Came home, went to put data on it, and it will only hold 591mb.
computer reads 2gb. as did my phone
GRR im leaving on thursday for cali and want more music on my phone WTFF!
