need help asap
hey i need help my sr when i have the lights on there bright than when i go to turn the key to start the motor it turns and turns and the lights dim to almost nothing when the battery is new and the motor slowly turns over but wont fire please help
try to boost the car from an other that is running. just to make sure you have lots of power to start.
If same thing happens sounds like your starter is on its way out or your engine is. do you have new oil in it? stupid question but still.
Ya its got new oil in it I got a mad power draw
has the car been sitting for a while?
Ya I think my wire harness is fu*ked
probably screwed up starter. starter is probably draining to much power.
Hmm
figure out the problem?
