hey guys looking for some help - grabbed a set of nismo lmgt4’s specs are as follows:
18x8.5 +25
18x9.5 +30
car is an s13 chasis with near stock s15 fenders, just looking for good sizing on tires that will fit right without rubbing, any help would be appreciated thanks.
I just changed to 225/40/r18 tires on the front of my s13. That mounted on a 18 by 8 inch +25 with 5mm spacer and it rubs and i can’t get it to not rub. I have it low but not crazy low I have about 2 finger gap. So I say smaller side wall.
In the rear I put 245/40/R18 on a 18 by 9 +25 rim and I have my lips slightly rolled and and it doesn’t rub. It looks gangster.
i run a 235/40/18 on a 8+30 wheel up front on my S14 and it only rubs a bit when i pull hard through a corner.
your suspension has ALOT to do with rubbing etc.
if you have good coilovers you shouldnt have that much travel if you dial them in properly, then set your camber where you want and you should be solid.
if your tires are rubbing on the street dont you dare take it to the track. it took me months to get my coupe to where it wouldnt rub at high speed through hard corners even though it never ever rubbed on the street.
if you have low spring rates you’re going to have a tough time getting your wheels not to rub if you’re low.
i had that issue with a 265. put 10mm spacers on and rolled the fender = fine. running a 275 this year.
My front are only rubbing on hard turns, especially if I hit a bump during. The tires are not rubbing the fender but the liner. What do you do in this case? I already pounded the seam weld at the top flat so it wont cut the tire. Is pulling the liner the only option?
