Ok, couple technical questions. I am going to be trying to remove a transmission tomorrow in a junkyard and I need to know what I should be aware of.
First, the car is a 92 Lumina Z34 with a 5 spd.
Questions:
Do I need any special tools, for say removing the axles?
Once I unbolt the bell housing (and other visible parts) will the tranny just pull off the flywheel?
Will I need to drop the subframe, and if so, what size bolt should I be expecting?
Aside from the bellhousing bolts, and the mounts, are there any other points that hold the transmission on?
And technical help would be greatly appretiated. I am going tomorrow morning at like 9ish
