Need help with swap
Swapping my KA with another one, sure it’s easy for some but it’s my first time doing it and there’s a lot of things I might need or need to do that I’m not sure of.
So, if you know me or not and you’re bored, I’m offering $20 + food + drinks (beer, anything!) for you to sit there and tell me what I need to do. No dirty work involved!
Cars at Mississauga and Mayfield, if you’re interested give me a call - 905.965.0252, don’t post here (though I thank you for the bumps lol) cause I won’t be checking this. Dial-up ftl.
Get paid and fed to sit and dictate! Thanks ahead of time!
This is pretty detailed
  1. drain all the fluids - Rad , trans , engine , power steering
  2. disconnect the main upper harness starting from the fuel injector plugs and follow it to the maf - ( dont take it out of the car )
    disconnect lower wiring harness - alternator / starter etc
http://forums.nicoclub.com/zerothread/299950
wow slow down !! do i have to have the car inside or outside ???
farmer
i used the same thread as a guideline when i first did my swap
and have done 3 engine pulls on my own car since then.
Dont be intimidated … Its not that hard at all…
yeah sinse its ur first time just organize ur nuts and bolts. and try not making a mess that is when u loose things.
