NEED HELP!!!
Locked my keys in my EG anyone know any tips on getting in?
AAA
seeing if my mom has it i dont have it anymore…
brick:dunno:
j/k
haha jeff only if you install a new window for free! I knew I should of ripped up the carpet to get the spare key…
cue ball and a tube sock
Use a small wedge of wood to carefully pry the window from away from the the top of the door frame/roof. Once you have a small opening you can stick a large screwdriver or prybar into the gap and manipulate the door look to the open position. If your car has power locks it’s even easier. Just use a straightened coathanger to hit the power lock button and you’re in. Both techniques work quite well.
Easiest way into an EG hatch is to slightly pry the glass then use a mangled coathanger with a hooked end to reach down and yank the rear glass release then crawl in through the back.
