need paint removed????
well, im trying to repaint my grill since there was a spot that i didnt like. however i tried some of the paint stripper however it only removed some of it and its going to take forever. Can anyone blast this for me???
i need to have it blasted or what ever to remove all the paint. It cant be warped from the blasting since its a thin sheet metal piece.
I need this done asap since i dont like driving around in a bimmer with the grill missing.:tup:
isn’t your grill plastic?
i meant the metal trim that surrounds the kidney’s, and runs the length of the front end. Did you get my lat PM laffengas??
sandpaper my friend. cheap and easy.stripper was a bad idea.
did you try yelling at it yet?
^^^^ :lol:
aircraft remover?
ok, I yelled at it for a while and that took off a little. But not enough because my car is tough as nails like myself.lol
anyway, i had some chips spreading and i wasnt happy with the original fix someone had previously tried to do soooo, i decided to strip it down and start from scratch.
I used aircraft stripper once and it started to remove the paint and took alot of it off. Im just not a patiant kinda guy, so i was just wondering if someone had a blasting cabinet of some sort. However i will just apply a few more coats of aircraft stripper until it comes off. This is takeing too long.lol
I can help you out.
+1 for this guy. he is good people…
who should i contact??? can you send me some info???
i will PM you his cell number
:tup: this guy sure can. good guy, good work!!!
