Need Saftey help!!!
Like it says, need saftey help. I Need to know the saftey guideline and wat will be looked for. ive talk to shops and they all say look on mto’s web site and nothings there. I know theres this giant book but they wouldnt lend it out.
So, if any one knows everything they look for, good. I know the mechanics get a sheet to check off butt they wont give it to me. Anyone can get me one?
please help, oh an dont be like them and say breaks, tires, ect. cut that doesnt say anything, i know you need a measurement( what is it).
Thanks
no holes every light on the cars extior must work wheels must be sucure on leaks in the breaks or fuel lines tire must have decent tread brake pads and rotors must be in good shapeno hole in the cab(where exhuast could get in) there is a huge list
tread lfe and brakes over %60
yea i guess the main thing is ive built in new floors but donno if i need to weld or if tack then tars ok. Also im boxing the frame in, i guess 20 gage steels alright welded through out?
kollo- would you know where i could get a hold of that huge list?
i guess main things i need to know is about body work and if the horn has to be in the steering wheel or can it be on a toggle?
anyone know anything else?
I believe you also need working e-brake.
20 gauge is really thin for a frame, i would suggest something thicker. as long as it can be lifted up on a hoist by the frame rails and has no holes, then it will probably be fine for a safety, but i would go with something thicker that will last longer. the factory frame rails are a lot thicker than 20 gauge.
  1. bodywork - underbody
  2. body work - hinges and latches
  3. body work - sheet metal and bumpers
  4. seat and seat belt assemblies
  5. chassis frame components
  6. mirrors
  7. glazing materials
  8. windshield wiper, washer and defroster
  9. speedometer
  10. lamps and reflectors
  11. headlamp aim
  12. fuel system components
  13. exhaust system components
  14. brakes - drums and discs
  15. brakes - friction materials
  16. brakes - hydraulic system components
  17. brakes - mechanical components
  18. brakes - air system components
  19. brakes - vacuum system components
  20. brakes - parking brake performance, adjustment
  21. brakes - service brake performance, adjustment
  22. brakes - emergency brake performance
  23. brakes - dual system warning
  24. horn
  25. accelorator linkage
  26. steering - column and box
  27. steering - linkage
  28. steering -power assist
  29. suspension - ball joints
  30. suspension - springs
  31. suspension - other items
  32. neutral starting switch
  33. tires
  34. wheels - rims and fasteners
  35. trailer hitches
  36. fifth wheel
Additional for motorcycles
  1. wiring
  2. footrests
  3. steering head bearings
  4. handlebars
  5. stands
  6. chain and guards
this is directley from the safety standards certificate book. it’s on the back of ever safety.
pending on the shop and it’s owner/s some places are extremely strict. some are not.
as for holes in body/frame. as long as everything is sealed and shut. and i can not poke my finger/screw driver through it. body passes
i think this should be stickied
factory frames in japanese cars are just layers of sheet metal over lapped
http://www.e-laws.gov.on.ca/html/regs/english/elaws_regs_900611_e.htm#BK6
