again guys THIS CARS HAS NO DOOR HANDLES JUST DOOR POPPERS HE NEEDS TO HIT THE AUX BUTTON ON THE KEY FOB
Done it at least 3 times with just a wedge and coat hanger, if you want to try a slim jim call josh we have one at work
Does it have a sunroof? Can you get in that way?
coat hangers really come to the rescue for guys in so many ways… thats right…
Yes we know that but if the door handle had anything to do with opening a locked door, why would one need a slim-jim?
If you don’t have a wedge…get a stiff piece of plastic (Pocket comb with a thick handle works fine) and then the coat hanger, I use an Antenna. Jam the comb between the rubber on the pillar and the window. Pry back just enough to make a gap between the rubber and glass. You won’t break the window as long as you don’t hit the edge with the antenna too hard. So be careful. (OT an easy way to break a window, if it is rolled down a little is to take a screwdriver, with a pointed shank like craftsman flatheads, and just drag it along the top edge…instant breakage) Anyways, now pull the lock. Not sure what the Mustang has as far as a little flippy lock swtich or something to pull up on. Or just hit the unlock button. I have done this many times to open junk cars at M&M before but only on cars without the frame around the window. Antenna works best because it is pretty stiff unlike a cheap coat hanger.
This is an old skool trick someone showed me. Takes about a minute to do. Pretty scary how easy it can be to break into a “older” car with a god damn pocket comb. Snap off the antenna, bend the end of the antenna(some antennas are a BITCH so you may need pliers), jam your pocket comb in the window, pop the lock, and you are in. Older style Neons are the easiest to do this to.
^^^ the door is unlocked. The problem is I can’t get the door open without hitting the button on the fob or pulling the handle.
Oh, so you need to activate your poppers then. Then Fuck…I don’t know. Doesn’t sound like getting in trunk will help you anyways. Unless, you can crawl through to the cabin.
You may have to smash something or punch out the trunk lock.
i never said use a slim jim. I went off topic. unless the owner installed a secondary switch on the car you are fucked. either break the trunk lock cylinder or smash a window
