need some help
why would gas spray out the valves when you try to turn on the motor…its a b18 btw
Because the spark plugs aren’t burning it.
Put a little more detail into your question and it will help everyone help you.
What valves are you talking about? Intake valves in the head? How do you know these valves are spraying fuel? Are you turning the car over without spark plugs in it? Fill us in so everyone knows what is going on.
its spraying out the head, i dnt have the headers on nd when i went to go turn the car over gas just started spraying out the first valve, then i took the first spark plug out to see what would happen nand it sprayed from the top too
So without the exhaust on, gas prayed out the exhaust port on the head, as well as the spark plug opening when the plug was pulled? You’re definitely not getting spark for some reason.
simply put, it’s spraying out because it is not burning off, and it needs a place to go.
