OK, i unpluged my O2 sensor and im not sure if i pluged the 4 wires back in correctly. I think there is 2 white a black and a green. correct me if im wrong.
can someone tell me if i have them pluged in right?
imagine youself on your backing looking up at the plug feet under the front bumper, head near the cat. are the colored wires in the right places?
what vehical ? what year ?
im sure someone on here has a matching car and can take a look for you
this pic was given to me, can anyone back this color connection up b4 i try it
yep. That looks about right…
Here i took a couple of pics of mine. It looks just like the one you posted…
Hope it helps.
Good Luck!
edit: PM me if you need the pic again
baller son!!!
what yr model is yours? gen 3 gsr? does it matter u think
ide be willing to bet that all 02 sensors within the same obd are the same
mines a obd1, if he has a 96+ its a obd2…then it might changed
yep, u need to check the wiring on an obd1. im going to the junkyard later to collect some civic parts and check some stuff out. im not even sure where the o2 sensor is, but if u tell me or show me where the o2 sensor is ill check it out when i go.
wait, o2 snesor is the one on the exhaust???
EDIT: awnsered my own question once i thought about it for more then 2 seconds
yup o2 bung right into the exhaust after the header b4 the cat. it plugs into a clip right below the intake manifold
Mine was an obd1
I think they are all the same shit though…
yeah i checked it out today, its the same as in the above pictures
sweeeeeeeeeeeeeeeet, thanks!
