i have an SR’d hatch. i put my turbo setup back on today(needed to replace gaskets and hardware and such) I connected everything, started her up, and my oil feed line started pissing oil out of the end bolted to the block. it was leaking between the line and washer closest to the block. tried several washers and another banjo bolt yet it would still leak. the only thing that seems reasonable, is that there’s a nick on the line where it touches the washer.
whats everyones input? i was losing my mind trying to get it to stop leaking and had to give up till tmrw cause of work space. haaaaaalps.
