oil smells like gas a little
my oil smells like gas a little bit. the car runs good. I have a wide band and its not running rich, but i get a bit of black smoke and my oil smells a little like gas. Any reason why?
Bad rings?
I’ve been told by a good friend a little hint of gas is fine - at least on a
turbo motor that runs low AFRs).
How badly can you smell it?
Change your oil and smell the new oil right away, drive the car for 500km and if you smell gas again then you are most likely way too rich. Is there ever black smoke out your exhaust?
Had this prob last week… tho mine was alittle excessive… 3 blown injectors, stuck open. Filled those pistons with gas as well as crank case… fucked eh… got those fixed and then the driver for the fourth injector went in the ecu… running fine now… Maybe u have an injector thats stayin open?? Check ur rubber gas line in engine bay right after u shut ur car off… If the lines not under pressure for at least a bit then an injecter may be bleedin it off into into cylinder an seepin into crank case…
most likely is just blow-bys…
yes i get black smoke, injectors are good, i think the compression is good. 160 across .
