my interga is missing which iam guessing thats mainly y she lacking power but its back firing to not a lot just ever couple of nin what could it be
did plugs and wires
and waiting for cap and rotor now
did plugs and wires
were you drunk when you wrote this?
where did it go? did it go out for lunch?
we speak english here, well most of us, we would appreciate it if you did the same.
speaking in text messages format?
and yes i was pretty drunk!!!
After cap and rotor…check the following, from easiest to hardest to check.
Transmission side ground strap: corrosion, is it tightened down.
Ignitor / coil assembly (check primary and secondary resistance)
Wiring harness around dizzy, check for obvious damage
Examine timing gears and belt tension
