Possible torn engine mount?
I see a bunch of water randomly along a deserted road so i stop and rev it up then drop the clutch…Crazzzzy wheel hop it was Intense!! so i stopped because it was violently hopping. Now everythings quiet inside the car…and it doesnt have that same feeling when im driving, mainly starting to accelerate and when im shifting. Engine seems to be a bit loose when i push on it or rev it up but not a huge amount. Cars just as fast…just quiet and a diffrent feeling that i dont really like…even when i start it up the shifter wobbles around like crazy while shes cranking. What could i have damaged? I also noticed a slight sound coming threw the vents from in the engine compartment that sounds like your in the basement and sum1 upstairs has the tap on. its very faint but i cant trace it down under the hood…more than likley another problem but nothing abnormal for a 15 year old car…When hard cornering the inner wheel hops aswell:? im going to play around with the tire pressure up front. im more worried about what wheelhop did to the car. While im at it any advice on getting rid of wheelhop? I kno theres subframe bushings, anything else?
for rear wheel hop dont get the metal spacers, it still hops, get the polyurethance c-spacers for subframe so its an easy install and tighten her up, get replacement engine mounts, and a new tranny mount.as for the front wheel hop check your tc rod bushings, if they leaked out, than thats probably the problem
Ill look into subframe bushings soon as for the mounts ill save the hastle and do it when ever i decide i can afford the SR and hope the clip comes with good ones. also increasing my tire pressure made the front wheels hopp even worse…I dont think its the weather, i have the same problem with hot or cold tires. back down to 34psi ill see how that goes. Thanks
