I think that’s what it’s called but I’m looking or the white box in the driver door that has two relays in it that powers the windows
Call me 647 290 3741 thanks
These all seem to fail in the same way. If you open it up you will likely see broken solder connection of one of the pins to the circuit board. I just soldered that broken pin and it was good to go
Thanks dude I’ll give that a try right now, when I hit the button for the window to go down I hear it click but nothing happens, motor is good because I bypassed the switch with direct power and it worked, however bypassing the switch also means I bypassed the amp box so I figured it could only be that, I’ll give it a try and see what I find if all else fails I’ll continue to look for one lol
I was hearing the click and my motor worked with direct power. Follow the circuit on the board leading to the relays and you’ll find the burnt connection.
The burnt connection is the hole circuit board, half of the board melted
