Okay so i was just rolling up my window, and i don’t know if i heard a noise or not, but soon after, the window starts to roll down…
i ripped the door skin off, and whenever i flick the switch the motor spins
and it spins the 2 sprockets. What i believe the problem is, from feeling around
and picking up a broken white piece of pulley, that motor has a sprocket attached at the end, and that sprocket spins another sprocket that is
joined side by side with a plastic pulley that pulls the cable up and down
The question is, can i pull the whole window unit along with the rails
as one unit? I can’t figure out a way to replace that sprocket without
having some good clearance for my hand to work around in…
then how can i replace the pulley? it’s like on the backside
of the sprocket (the one on the right that gets driven by the motor)
has anyone ever had this happen?
