i have a89 wtih a bone stock ka24e. awsome car, love it to death, will never buy another car. first thing is first, soe background on what happened.
- i’m driving my car, everything is great, on my way to get an oil change. get there and it’s HOT, never had a problem with my temp b4, it’s gets warm and stays there. never moves from it’s spot, always the same. the guy burns his hand on the oil, another guys starts saying something about antifreeze in my oil. i know thats not good. blown gasket, cracked block list goes on. so i get my oil changed, they don’t say nothing to me about it, i just happened to hear them talking. i leave, i notie i have barely any power, white smoke is coming out my car and it’s over heating again. i’m suppose to be taking a 9 hour road trip in 30 mins. not good. i also bought expensive plugs and a k&n air filter to go with this oil change for my trip.
 no go on the trip, i park my car, and figure it’s the head gasket.
a year later(like 2 weeks ago) i put the batter in my car and she fires up as if she’s been running all this time. i let her idle for a bit, check the temp, nothing. it’s smoking, not white smoke, but just smoke. i take her for a rip up the street, she smokes really bad, sounds like it’s missing in between 1-3 rpm’s accel and decel, after my little cruise, the temp meter, still nothing. i bring her home and park her again. started to think, what if it isn’t my head gasket, and rather just my thermostat(if thats the chase, i’m gonna be mad if i parked my car for a year b/c of the thermostat!!!
i’ve been on ebay for the last 2 weeks ordering stuff like crazy.
the guides for the timing chain are worn right off, so the chain is rubbing on metal, makes a nice rattle sound!! another problem, but soon to be solved.
i bought,
- new front struts (130$)
- pillow ball chamber strut mounts.($150)(oem ones are cracking very baddly)
- ecu($45)(gets rid of speed limiter and rev limtier claims made 30 hp on dyno.)
- timing kit(50$)( all guides, top and bottom sproket, chain, seals etc)
- head gaket set(80$) (all gaskets you can think of on the top end)
- head bolt set(50$)
- engine torgue damper(connects engine to strut pillar to stop engine movment, keep the power on the driveline)
- jdm mirrors, front bumper, hood plus more stuff not dealing with motor.
- performance thermostat(40$)(opens at 75 instead of stock, around 90 i think something like that)
another problem i have, its the clutch(ebay $180 stge 1 clutch have boughten it yet, but soon!) i push the pedal in, and when i let it out, it doesn’t come all the way out, it doesn’t seem to grab like it use to. some ppl say screw the rod, some say its the slave. the guy that had it b4 me(x g/f’s little bro) got some work done on the clutch, whart i can’t remember, but the problem was that u could rev it up and drop the clutch and it would just keep rev’n. clutvh was slipping like crazy. couldn’t smoke the tires at all. i think he had to weld something b/c i remeber him saying something about having to fabercate something. the clutch worked like new after that(drove it b4 and after) what a difference! i wanna replace it with the one of ebay anyways, but do you think i should also replace the master and the slave as well, or just try and bleed it and see if that works? or just wait for the new clucth(can’t drive it right now anyways) and see if it all works, bleed it then and try it.
hey another problem! i drive around, and i notice that my rims get very very hot. usually my back ones. not so much the front but sometimes. it was so bad one time, that i was driving around and it was stoppin the car, i had to rev the piss outa it just to get it to move, i was in the middle of rush hour, with a car that didn’t wanna go anywere, so i pulled off to a side street and let her cool. she was fine after that. sometimes i notice if it was sticking like that, i would back up about 6 ft and it would be fine after that. or i would just let it cool down and everything is a ok. doesn’t make any sence to me.
my back wiper, i come home, the rear wiper is on and working, i don’t shut it off, but rather just shut the car off, and go inside, wake up the next day, the wiper doesn’t work anymore. i can’t spray the water, or turn the wiper on. front ones work just fine. any ideas?
idle, doesn’t wanna idle under 1300. never had this problem b4. checked all my hose’s, doesn’t seem to be any leaks. never touched my idler b4.
ive been all over the net try’n to find answers to these ?'s. but no one seems to be able to give me an answer. i’ve read alot of the topics on here that might have related to my problems(clutch one for sure) but there is way to many to go through them all. i’m hoping that someone will be able to give me the answers i need and want!! i’m tired of walking and really really really miss driving my 240.
someone told me it could be my air sensor or exhaust. i don’t know what the last time they were changed, should i change them anyways? i’m doing all this work, to make it run right would it be worth it to spend the money on these sensor’s?
please help me!
i’m some what mechanical able. i can’t do everything myself, but i have a very good idea, and i know what i need to know. my dad’s a mechanic and has his own shop. i’ve learnt from him. but he doesn’t wanna fix my “jap crap”. ppfffh he’s just scared!! lol
