after recently finishing the boosted focus, it was discovered that the wideband we had was not working for us
a friend of mine was nice enough to let us borrow his aem wideband for the sake of getting the car tuned.
i must say, i like the AEM setup much better then the L-C1 ive previously used
everything on the aem is plug and play, put the WB in the exhaust, the gauge in the dash, plug in the wires, hook up the power and ground and your done.
theres also an alalog output wire, and a Serial data stream outputwire
in our case we connected the analog wire to Nicks SCT pro racer software for AFR logging, and using the simple formula of “vx2=10” in his software, we always have afr displayed as an afr# instead of a lambda number
with the LC-1, you have to do a free air calibration before you can use it, you have to set up the graphs for the analog output’s, and -at least as late as last summer and possibly still true - you have to download new software and firmware from the website to replace WHAT ALREADY COMES INSTALLED. not to mention that the LC1 uses a 9 pin cable, and if you dont have a laptop w/ a 9 pin connction you cany use a usb adapter, because even with the best adapter & drivr set, its still glitchy at best
considering the LC-1 is $210 (no gauge) and the AEM is $270 WITH a gauge, $60 extra in price gives you a wideband thats way easier to setup, less problems, less wiring, AND you get a gauge that can be used stand alone, so you dont HAVE to have a laptop to run the AEM
AEM > innovate motorsports …
