This is in my opinion a fairly huge build, and seeing as I am a full time Mechanical Engineering student at Conestoga and work part time at RONA, there is no set deadline on this build (low budget per pay etc, working on it one day a week.), but in the end it will be minty fresh
Soo, this build started as an 1990 SOHC 240SX hatch, KA24Power’s old car. Probably should not have sold this car, but I wouldnt have an S30 if i didn’t lol.
I sold that to Kollo (who is building it now), and bought a black 1995 Zenki 240 off Simplemind7.
The S14 was f*cked. It looked fairly clean underneath - but that turned out to be massive amounts of bondo, fiberglass, hot glue gun sticks, drywall mesh tape, cardboard, hockey tape and duck tape used to fix anything wrong with it :/: The floor was soggy. I’ve never seen anything like it. The floor was solid at the frame rail joint, but the floor folded down around the frame at least an inch at the greatest movement. Wasn’t rusted out or anything, just… soggy. (NOTE: I am in no way blaming Brendan for doing these things to it - I know thats not his style - whoever did do this however deserves a punch in the ovaries). Fenders and front bumper were held on with self tapping zinc plated screws…
My entire direction for this build changed in the past 3 days. Friday night an idea came upon me, and I researched. Saturday night I went and took a look at a disassembled car and put a deposit down. Sunday night, much thanks to a few guys helping me out huge (David, Ben and John), I picked up said disassembled car and brought it to my shop. I picked up an entire 1973 240Z, in parts, for a extremely good price.
Don’t mind the surface rust on the frame rail - they’re 100x more solid than any S13 rail I’ve seen lol.
Looks half decent with some Blitz Type 03’s…
Spent some money on these that probably shouldve been spent on the Datsun lol. Oh well. Green XJ daily - then S13 daily - now red WJ daily - need new pics with lift and other mods.
Due to various reasons, left my shop in Tavistock (~2000 sqft) and crammed everything into my garage (~200 sq ft) FML. Space is a little tight. Working @ Rona part time has its benefits i.e. 1.25" thick melamine workbench for ~$5. I’ll miss the shop mascot though.
Figured it was time for a legit rotisserie -
Stripped all paint off the car, as well as up to 3/8" thick of bondo off the roof and rear quarters even though the metal on the roof was perfect, and it looked as though they tried to reshape the contours of the rear for no particular reason. Used stripper, sandblaster as well as blowtorch and scraper. Primered it, and will get little spot touch ups when time comes for paint.
I’m set for fuel, cams, efan, fidanza,
5 bolt had to be removed from R34 GTR knuckle so I can use the Z32 big spline 5 lug. It appears as though the GTR knuckle is an aluminum version of the S14 which would eliminate the issue of coilovers for you guys that upgrade to Z32 uprights and need to switch bottom mounts.
Step 1: 3 Jackstands and a BFH.
Step 2: Booya.
Z32 Big Spline 5 Lug, S14 Front spindles, FLCA. Bushing on the FLCA had to be ground down 1/16" to fit the S30 Subframe…
Garrett GT3076R 0.60 A/R - Super Legit Paperweight.
Z33 VQ35 6 Speed
Vs. KA
A little bit of the dirty work. The name of the paint stripper is true… As are the warning symbols
Second pic shows one coat of stripper left on for 10 minutes which was wiped off and then a coat of easy off to degrease. Works wonders.
Started cleaning up / primering parts while my money is tied up in school. That way when I buy all the remaining parts I can assemble shit without waiting around on cleaning em
Also, started to measure & design my build in Solidworks. Have the 5 lug, Q45 output shafts, Brake rotors, as well as starting on engine. For dreaming purposes the KA crank is fully balanced, but i’ll be changing it to realism someday…
Picked up a new cowl piece - thx JP.
This probably shouldn’t have been used as a amp ground wire…
A buddy hooked me up with a E36 M3 Dash, centre console, glovebox, trim etc. (Picture not of mine). Will need a tiny bit of trimming obviously, but is almost the same curve and width as S30. E46 M3 Cluster looks alot nicer, so i’ll probably end up going for it.
If someone wants a FG S30 replica to start off of you can have it for a doubledouble :D.
The black 240z has a roughly similar end product as what I want, however mine will be a fair bit wider. Talks with Weirtech about a cage for the Z similar to this, but with adjusments to meet spec here:
Good news is that I bought a ZEDD Findings floor kit which is perfect as I am lifting the floors 1 3/4" to 2", as they sit below the rockers, and would scrape like nobody’s business. I need to fab up my own GTR subframe mount and will probably make my own floor rails as the ZEDD findings ones are just bent 18ga sheet. After major components are fabbed up, I will take the car on rotisserie to nearest Rhinoliner and spray the entire bottom - stiffens the hell out of it, sound deadens, as well as the obvious rust proofing bonus…
I am also researching some form of skid plate to protect a Xcessive Manufacturing/Greddy sump oilpan from gnarly speedbumps.
My new friend.
Most importantly, you have to have the gf who puts up with all your car addiction bs
i figured it wouldve gone alot quicker but this little bit took over an hour with a knotted wire brush on an angle grinder.
After grinding:
After primer;
Cleaned up and painted the Z32 5 lug and BNR34 knuckles.
Also kept busy lifting my daily - this is beside a stocker. 3" IRO lift which lifted it 4.375" all around before sag and is at about 4.25" after 2 weeks.
Here’s some more-
Beforish:
After a couple hours:
Started cutting off all those annoying clip things.
Bought one of these: Q45 90mm throttle body + tps.
I should probably apologize somewhere in the thread for taking all pics with my iPhone - not the greatest quality.
Also, subframe is sandblasted just needs to get picked up and slapped on, so I can start on S13 coilover conversion on S14 arms…
My wallet hates me.
Started hacking the E36 dash with a dremel + sawblade.
Thinking about taking off these drip trays - i think it’ll look hell of a lot better… thoughts?
Soo the only reason I was using the M3 E36 dash was because a stock one cost a fortune in good shape. Until I met an old guy who lives a few streets over from me and he hooked me up.
'72 240Z Dash - professionally restored
Heater center vent
Centre Console
All necessary tubing
BNIB dash side vents
Glove box
Dash to windshield trim
Dash harness (not needed I’m doing new gauges throughout)
Front Grille
Hood hinges
Tail light finisher pieces
Price for all of the above? $280. The only person here who probably appreciates how much of a steal that is, is Janaka, JP and some others.
Enough speak, more pics.
Also started fitting the S14 suspension
And fabbed up some arms to hold the front on rotisserie.
Soo I got an email from the guy that I bought my dash from about a hood for sale out in Brantford. I headed out there after work and met Chris and Rob - couple of bro’s that have a pair of Datsun Z cars - one of them RB swapped. Cool dudes - sold me this hood for $50
Then I got to work on the front half of the rotisserie - s’all done. The rear half will be done up on Tuesday.
Soo Tim is pretty good at photochop and made this for me.
I’m a fan. This will happen + spoiler + black window trim - headlight covers.
Joe came over last night and we talked about expensive things…
- 4-6 point cage, X bar tied into the rear R34 Subframe mount, 2 to strut towers, harness bars across. Tucked to cnt-hairs width from the roof and sides.
- R34 rear subframe mount.
- Fender brace that runs along the dogleg and around tucked to upper rad support and back around the other side (Beginnings of a tube front end).
Cage looks a lot like this…
And rear subframe mounted alot like this:
Also just sketched this up for mounting the rear of the R34 GTR subframe - thoughts on improvements/weaknesses? Its similar but alot different to that setup ^. For those unfamiliar with isometric drawings, the right side is a sectioned view to show what the fastener is doing. The darker grey blob is actually supposed to be a 3/4x6" hex head bolt but Solidworks is weaksauce at displaying true fastener sizing.
PIG ROAST!!
Finally got off my ass and finished the rotisserie.
Rear welds are fairly solid.
Need to bolt the arms to the T-bar before I try spinning it lol.
For those who care.
Almost THEORETICALLY have it figured out how to rock a fully counterweighted crank in a KA block with KA piston.
Rod is out of a Ford 5.4 Modular Motor, longer rod than a KA by about 5mm. Bushings need to be drilled out or replaced, or the KA piston needs a 22mm pin instead of it’s 21mm. Crankshaft is a L20B/Z20E/Z20S U60 casting.
The other options I have listed include a Toyota Celica 20R 90mm Piston with various rods that will work - LS1, Viper V10, Ford w/ Chevy Pin, but I would like to try it with the KA piston first.
Braaap.
In due time, after some paychecks, I’ll make this happen and post up how it is.
Had an hour or so to work on er tonight…
Also had a package come in the mail. I <3 when that happens. Todays xmas present was a Q45 90mm throttle body+tps (thx godrifttoday)
Couple of comparison shots with a stock KA ~60mm tb…
Bolted er up.
Spun er right round.
Cleaned some crap off.
Primered er up.
Including my freshly blasted subframe…
Most productive hour of my day
Had a few hours to work on the Z (I need a good name for her)…
Started with one of these…
Drilled a crapload of holes…
Cleaned the bish.
Primed a bit
Also, bought one of these to complete my modernized suspension - JDM S14 swaybar 27mm w/ JDM S14 TC brackets. Also doubles as a rad mount and I can now order S14 sizes with install ease… Not bad for $45 lol.
Might work on er again tonight and see how far I gets
Sorry for the delay boys…
My co-op term ended so I took the gf to Santa Maria, Cuba to celebrate. Things got silly and we had drinking team tshirts made up for the group lol.
Did a bit more cleaning up on the underside the day I got back.
Started on the passenger side.
Exams are almost done so I got antsy… ZEDD Findings Floorpans took soo much work to fit, I was mildly ticked.
Mocked up Sentra front coilover, S14 arm + spindle - Time to order some HSD S13 coilovers and make some camber plates.
Cleaned up drivers side front well tonight - 3 more nights of working like this and the car will be entirely primed
Got to cuttin and cleanin last night, got some fittin and weldin tonight.
