Ya, I was hoping to clear all the confusion up, but it doesn’t seem to help much.
However, summary.
When coming to a stop at a light, Shift to neutral and sit on the brake until 1st gear is needed. (For the sake of skipping the argument, I’ll just say it’s easier to put the car in neutral and coast down, instead of continually downshifting)
Rev match when possible.
When skipping a gear (3rd to 5th), move the shifter from 3rd -> 4th… Pause for a moment in 4th, then move the shifter to 5th and release the clutch as normal.
Anyone have any suggestions as far as Backing up/going through a parking lot w/ a Cam and not riding the clutch?
Any time I’m under 10mph in 1st the car jumps and bounces around. Once I get above that, or put a decent amount of gas on it, it will stop.
Typically I’ve been Speeding up to ~12 or so… then let it coast down until it gets rough, put the clutch all the way in, wait until it gets down to about 5 or so… Then speed up w/ no clutch to about 12 again… then coast back down and repeat…
There were things saying about switching to neutral and 1st, or neutral and reverse. Which I suppose I could do, instead of letting it coast down with my foot on the clutch, put it in neutral after I speed up… then switch back in to first when needed, then back to neutral…
More tricky with reverse though, since reverse is a PITA to get in to.
