Well you bickering fucks have probably managed to thoroughly confuse the original poster. Hopefully he stopped reading after the first few responses.
Can we all agree that in a normal (not modded) car, using engine braking to slow down (without doing stupid shit like dropping a gear or two and sidestepping the clutch) will have do measurable/noticable damage to the car?
It all goes back to as a general rule, if it feels smooth it’s probably OK.
I will add an obvious fact I probably skipped over in this thread:
Never Down shift into 1st gear.
Honestly, just get someone to show it to you if you don’t get it or are having trouble. And don’t be scared about burning out the clutch, they are designed to be able to take a beating from everyday driving. It’ll be hard for you to get it this shit over reading, its a skill that is learned through practice. I still throw my 88 year old gramps the keys and he’ll drive anything flawlessly. Once you have this skill, you’ll have it for life. But do try to develop good habits. Bad habits are hard to break- my retarded ex rides the clutch horribly, blaming it on habit…
It can be done. Instead of dismissing it all together you should clarify that you should not shift into first until you have mastered downshifting for your car. This is something I have had to adjust to with a Mid-engine car in really TIGHT turns as lift off is ultimately a bad thing (Thanks Joe :))
A better explanation would be IMO: If you want to downshift into first you should learn where your power ban is from first to second. After you know that make sure you don’t downshift at too high an RPM. If your power ban kicks in around 3200 in first and your engine drops to say 2500 when in second try to stay well below 2500 when downshifting to first. You don’t want a 4 grand drop into first while rolling 25 MPH.
I usually get down to a sputter in second before I hit first. Around 1100 RPMs.
Learn the basics, and learn to be as smooth as possible. Then go figure out all the other crap in here… geeze… just go out and drive you car. Clutches are cheap, and unless you pull a Skunk and do a 5-2 shift you should be fine. T-56s take a pretty good amount of abuse before you do any serious damage.
Driving it is all feel and touch. You will eventually know whats better. Revving the engine when the clutch is 1/2 way out is bad tho any way you look at it.
I personally only downshift if I am going into a turn to slow down vs hitting the brakes. At a red light I just sometimes downshift once and then thats it becuase personally a transmission repair is a lot more expensive than a brake job but I don’t think anyone has a full answer on that theory.
My sunfire went 115k miles on the original clutch and transmission so I must have done something right.
If you shift and your passengers hit their head on the seat in front of them or the dashboard, you are doing it wrong.
I’ll take my advice from an established organization, and I will continue to stick with the “brakes are for decelerating, engines are for accelerating” method. It hasn’t let me down yet, and my car runs great.
Here is some awesome info on upshifting, the concept here should apply to daily driving as well as spirited driving:
I’ve been doing a good amount of research. I have not found any engineering/science based articles on engine braking though.
Because people on a road course don’t really worry about things like "being in control if a deer runs in front of you. They don’t care about gas mileage.
The truth is, if you engine brake, at any time, you can hit the gas or brake to speed up or slow down, you are still in control of your car. If you are in neutral braking, and you need to speed up for something, you can’t react fast enough.
As for gas mileage, if you are engine braking, your injectors are not firing, and you are saving fuel. If you are in neutral, you injectors need to go, to maintain a ~ 900 rpm idle, using fuel.
That are just two things that come to mind first. There are two other things in this thread I would like to discuss too. And in no way am I flaming, or arguing, just debating with my education. The argument that the engine can get hurt from engine braking is ridiculous. Engine braking = no combustion. Normal driving, or 100x worse yet, WOT with a boosted car, will put so much more stress on the pistons and cylinder walls compared to engine braking. Engine braking is simply the pistons moving up and down with no engine load, so saying that your compression of your motor can affect how bad it is to engine brake, etc… Is just silly.
Next, rev matching is better on the clutch (life of the clutch) than putting it into gear, and letting the clutch change the rpm. That is the whole point of rev matching, to safe the clutch and drivetrain from extra wear and extra drivetrain shock.
And lasty, the argument that brakes are cheaper than clutches… not always true. The clutch disk is only going to wear at a noticeable rate if you are slipping it. Normal engaging / disengaging does not really wear a clutch much at all. The pressure plate and TOB could wear more, but that is why they are there, to use.
I am not even going to touch some of the other rediculous statements in this thread, but yeah, that’s physics and experience talking, not just internet whoohaa.
I want to find some information on what happens inside the transmission during engine braking. Is the load exerted such that it will cause harm to the transmission, or is it the same as normal driving?
Theoretically, yes. In most realities, meh you’ll probably never damage a transmission by engine braking as a habit. Unless you habitually downshift at high rpms and sidestep the clutch without giving it any gas for years. Or have an Italian car. Or a GTR? :rimshot:
